Is this supply-air temperature a variable that exists among the outputs?
Hello,
I’m using BEopt 3.1 with the EnergyPlus engine to compare a gas furnace and an air-source heat pump, and I’d like to look directly at supply-air temperatures for the heating equipment to better understand duct losses. Is this supply-air temperature a variable that exists among the outputs?
Are there any hourly output variables that would correspond to supply-air temperature for the main heating system?
Hello,
