How simulate a GSHP coupled to TABS in OS?
Hello! I am trying to simulate a cooling system consisting of: a Ground Source Heat Pump connected to a Low Temperature Radiant System. I'm confused about how I must define the condenser and evaporator loops (Ground Heat Exchanger and RadiantSystem, respectily) of the Heat Pump. I would be grateful if you could guide me to correctly define these connections in the Plant Loop.
