BEopt v3.0.1.0 - Error: "Cannot find corresponding design option in design" during Detailed Report generation
Hi all,
I'm encountering a critical error in BEopt v3.0.1.0 when trying to generate a Detailed Report. The application crashes with the following message:
Message:
The following application error has occurred in BEopt v3.0.1.0.  Please report this to the BEopt development team and restart the application.
Unable to write output report to file
Inner Exception:
Source:
BEopt.ObjLibCS
TargetSite:
NREL.BEopt.ObjLibCS.DesignOption GetCorrespondingDesignOption(NREL.BEopt.ObjLibCS.BEoptDesign)
Message:
Cannot find corresponding design option in design.
Stack Trace:
   at NREL.BEopt.ObjLibCS.Option.GetCorrespondingDesignOption(BEoptDesign aDesign) in C:\git\beopt\Source\BEoptObjLibCS\Measures\Option.cs:line 609
   at NREL.BEopt.ObjLibCS.BEoptCase.GenerateDetailedReport(String fileName, Int32 numReportsGenerated, Int32 numReportsToGenerate, Action`2 UpdateProgressBar) in C:\git\beopt\Source\BEoptObjLibCS\BEoptCase.cs:line 1181
   at NREL.BEopt.BEoptUIVB.BEopt_MainForm.GenerateDetailedReportToolStripMenuItem_Click(Object sender, EventArgs e) in C:\git\beopt\Source\BEopt\BEopt_MainForm.vb:line 737
What I’ve tried so far: - Restarted BEopt and reopened the file - Verified that the design options in each case appear complete (no blank fields or missing measures) - Attempted report generation on other design cases in the same project, none of them work - I'm not manually editing .bld files
Question: - Is there a way to identify the specific problematic option? - Are there known bugs or workarounds for this version of BEopt?
Link to the project: https://drive.google.com/file/d/1lX0xRRjE6psCyB3x4d1NVPej7zokqywH/view?usp=sharing
Thanks in advance for your help!
Hi all,
Message:
Inner Exception:
Source:
BEopt.ObjLibCS
TargetSite:
Message:
Stack Trace:
Hi all,
Message:
Inner Exception:
Source:
BEopt.ObjLibCS
TargetSite:
Message:
Stack Trace:
What I’ve tried so far: - far:
  • Restarted BEopt and reopened the file - file
  • Verified that the design options in each case appear complete (no blank fields or missing measures) - measures)
  • Attempted report generation on other design cases in the same project, none of them work - work
  • I'm not manually editing .bld files
    Question: -
Question:
  • Is there a way to identify the specific problematic option? - option?
  • Are there known bugs or workarounds for this version of BEopt?
