Hi,
I've been using HAMT simulation within E+. I've noticed that the initial water content in the run period is not what I defined in the IDF.
In the example below, the starting water content ratio is below 0.3, the value I defined in the IDF. My guess is that it changed after the warm-up period.
Has anyone run into the same issue? And how have you solved this?
