Does heat pump have higher peak consumption compared to central ac system?
I modeled a single family detached unit with two different cooling system 1) central ac 2) heat pump (same efficiency rating and capacity for both system).
I varied construction materials i.e., windows (double pane, triple pane), insulation R-values, roof colors, etc to better understand the energy use changes from each cooling system.
I also tested various weather cases (different locations, TMY, AMY, etc).
My results for MAX (Peak Load) vs. Sum (Annual Load) of hourly result of 'End Use: Electricity: Cooling' is shown below. It shows that heat pump (teal color) resulted in higher peak load than central ac (red color).
Why is that? Does higher air temperature make heat pump less efficient? I thought central ac and heat pump are the same for cooling.
I modeled a single family detached unit with two different cooling system 1) systems
  1. central ac 2)
  2. heat pump (same efficiency rating and capacity for both system).
    system)
My results for MAX (Peak Load) vs. Sum (Annual Load) of hourly result of 'End Use: Electricity: Cooling' is shown below. below. It shows that heat pump (teal color) resulted in higher peak load than central ac (red color).
I modeled a single family detached unit with two different cooling systems
  1. central ac
I modeled a single family detached unit with two different cooling systemssystems using openstudio hpxml.
  1. central ac
click to hide/show revision 5
retagged
I modeled a single family detached unit with two different cooling systems using openstudio hpxml.
  1. central ac
