Failed to add measure detailed as Failed to compute arguments for measure.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the lastest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way.https://unmethours.com/question/32678/what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project/ However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the lastest latest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way.https://unmethours.com/question/32678/what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project/ However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the latest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way.https://unmethours.com/question/32678/what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project/ way. https://unmethours.com/question/32678/what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project/ However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the latest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way. https://unmethours.com/question/32678/what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project/ link text However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the latest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way. link textwhat-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
Greetings. I am a new user of OpenStudio. The version of the software I am using OpenStudio SDK 3.8.0 with openstudioapplication-1.8.0-rc3 and SketchUp 2024. When I imported an OS file that was used in OpenStudio 3.7.0 into the latest one, an error occurred when I tried to run the simulation, and no eplusout.err file was generated. The error message was "Simulation failed to run, with exit code 1," and there was unable to load the measure named "openstudio_results." After deleting the measure, I found that I could no longer add it back for the error showed in the picture.image description I attempted to fix the issue by downloading the latest version of the measure from the BCL, and this solution worked. After some research, I found that others who had encountered the same issue had resolved it in the same way. what-is-the-possible-reason-for-failed-to-add-measure-failed-to-add-measure-to-the-project However, I am wondering about the possible reasons for an issue like this. Additionally, I would like to know if, when updating versions, built-in measures in OpenStudio are not updated along with the new version installation and must always be updated through the BCL. Could this issue be related to changes in the software's file path during the simulation? I would greatly appreciate any suggestions you could provide.
