I run a simple parametric analysis in jEPlus v2.1 using the DOE medium office building. After simulating two parameters (U-factor and SHGC), I did not see the HTML file in the output folder. Moreover, eplustbl.csv did not retrieve any output.
I have tried the following solutions given in previous queries, but I have the same problem:
Output:Table:SummaryReports, AllSummary; !- Report 1 Name OutputControl:Table:Style, CommaAndHTML; !- Column Separator
Please what do I need to do to collect the HTML file?
I also received the message, "Warning: no report variable is defined. This project may not work with jEPlus+EA." How do I resolve this? Thank you.
