It sounds like the CreateCSVOutput OpenStudio measure might be what you're looking for. That'll give you a CSV file for output variables and meters in your model. In addition to adding output variables to the model as others have pointed out, you could add the Add Hourly Meters measure as well which will add several meters that will aggregate different heating and cooling categories for you.
