EnergyPlus 24.1.0 has a new feature that can simulate an indoor green wall using the input object IndoorGreenWall. The documentation for this is in the input output reference and the engineering reference. Version 3.8.0 I believe supports EnergyPlus 24.1.0.
EnergyPlus 24.1.0 has a new feature that can simulate an indoor green wall using the input object IndoorGreenWall. IndoorLivingWall. The documentation for this is in the input output reference and the engineering reference. Version 3.8.0 I believe supports EnergyPlus 24.1.0.
EnergyPlus 24.1.0 has a new feature that can simulate an indoor green wall using the input object IndoorLivingWall. The documentation for this is in the input output reference and the engineering reference. Version 3.8.0 OpenStudio version 3.8.0, I believe believe, supports EnergyPlus 24.1.0.24.1.0. This is for an indoor green wall.
