Similar to this previous post? I'd check your model for missing space type properties. In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem is tripping over missing space type properties.
Similar to this previous post? I'd check your model for missing space type properties. In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem itself (not the measure) is tripping over missing space type properties.
Similar to this previous post? I'd check your model for missing space type properties. In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem itself (not the measure) is tripping over missing space type properties.properties, which in turn may be generating your more severe error.
| 4 | No.4 Revision |
Similar to this previous post? I'd check your model for missing space type properties. In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem itself (not the measure) is tripping over missing space type properties, which in turn may be generating your more severe error.
EDIT: Double-check space type properties (under "Space Types" tab)?
| 5 | No.5 Revision |
Similar to this previous post? I'd check your model for missing space type properties. properties:
As stated in the video, it is not enough to simply assign space types to spaces. Assigned space types must have valid Standards entries, as show below.
In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem itself (not the measure) is tripping over missing space type properties, properties, which in turn may be generating your more severe error.
| 6 | No.6 Revision |
Similar to this previous post? I'd check your model for missing space type properties:
In a nutshell, the CreateBaselineBuilding Measure has OpenStudio-Standards as a gem dependency. The gem itself (not the measure) is tripping over missing space type properties, which in turn may be generating your more severe error.error. The warnings are clear enough: "template" is OK, yet "building_type" and "space_type" entries are unfortunately nilled.
EDIT: Double-check space type properties properties (under "Space Types" tab)?
