Following the instructions on the wiki page allows you to build the entire package, but you could also substitute pieces into an existing installation if you want. The instructions include how to build an installer, including all the documentation and other pieces. The developers follow this same wiki for our builds. While the instructions are clear, it will probably take a couple of hours to complete the first time, and then, making changes, recompiling, and creating new installers should be easy. Good luck!
Make sure you follow the instructions specifically on building installer packages and make sure you right click on PACKAGE and build it:
It should create something like:
C:\repos\EnergyPlus12\build\EnergyPlus-24.1.0-f4280d1a4c-Windows-x86_64.exe
