Similar issue reported here (i.e. mismatch between schedule intervals and simulation timestep) - similar fix (i.e. adjust timestep duration or schedule intervals), or instead interpolate.
The more severe interzone construction layer mismatch errors are easy to fix - make sure adjacent surfaces reference constructions with the same number of layers. And if asymmetrical, in reverse order (see here).
The more severe interzone construction layer mismatch errors are easy to fix - make sure adjacent surfaces reference constructions with the same number of layers. And if layers (if asymmetrical, in reverse order (see order, see here).
