Shruti:
I ran into the same thing yesterday, lots of errors similar to yours that seemed to indicate problems with HVAC systems. But it was a fatal error that caused CSE not to run and that led to not generating the expected HVAC csv files that showed up in the log file. When I went into the folder with the supporting files for the run and opened up the .err file, I found out what the fatal CSE error was. In my case, I had a door that was 20 sf on a wall that was only 16 sf. So the lesson I learned was always to look at the .err file when things inexplicably won't run. Hope you figured out your situation OK! Once I corrected that it ran fine.
