Material is an abstract base class. You cannot instantiate it. You probably want StandardOpaqueMaterial since you mean to set a thickness (otherwise MasslessOpaqueMaterial is a possibility)
In [1]: import openstudio
In [2]: m = openstudio.model.Model()
In [3]: mat = openstudio.model.StandardOpaqueMaterial(m)
In [4]: mat.setThickness(0.3)
Out[4]: True
In [5]: print(mat)
OS:Material,
{355d42fb-f0e5-4e57-b0e8-a8d34651f095}, !- Handle
Material 1, !- Name
Smooth, !- Roughness
0.3, !- Thickness {m}
0.1, !- Conductivity {W/m-K}
0.1, !- Density {kg/m3}
1400; !- Specific Heat {J/kg-K}
Take a look at the inheritance diagram: https://s3.amazonaws.com/openstudio-sdk-documentation/cpp/OpenStudio-3.6.1-doc/model/html/classopenstudio_1_1model_1_1_material.html
