Depending on what you are modeling, you can select different systems. Typically, the available HVAC systems are to give you a good starting point which you would need to revise later depending on your system. A typical HVAC system for multifamily midrise is the RTU system. The demand side of this system will be connected to different thermal zones and the supply side could be a packaged system or it could be connected to a chiller plant and a boiler (all examples).
