The BCL measure prototypes are not intended to represent the DOE/PNNL .idf prototypes, as explained in the openstudio-standards documention. The BCL measure will be deprecated and replaced with a measure to create "typical" buildings to help clarify the distinction.
The method you use depends on your use case: - Code comparisons and determinations under the Energy Policy Act -> use the DOE/PNNL .idf prototypes - All other use cases -> use the typical building models / OpenStudio measure to create typical buildings.
The BCL measure prototypes are not intended to represent the DOE/PNNL .idf prototypes, as explained in the openstudio-standards documentiondocumentation. The BCL measure will be deprecated and replaced with a measure to create "typical" buildings to help clarify the distinction.
The BCL measure prototypes are not intended to represent the DOE/PNNL .idf prototypes, as explained in the openstudio-standards documentation. The BCL measure will be deprecated and replaced with a measure to create "typical" buildings to help clarify the distinction.
- case:
- prototypes
All other use cases -> use the typical building models / OpenStudio measure to create typical buildings.buildings
