Which AirTerminal object are you using? For setting air flow see the Input Output Reference...
AirTerminal:SingleDuct:ParallelPIU:Reheat
AirTerminal:SingleDuct:SeriesPIU:Reheat
This question has some resources for predicting fan power in EnergyPlus. Hope that helps.
Which AirTerminal object are you using? For setting air flow see the fields for these objects in the Input Output Reference...
For setting air flow see it looks like you can set the air flow using the fields for these objects in the Input Output Reference...objects.
This question has some resources for predicting For fan power in you'll need to use pressure rise to predict the output W and W/cfm from EnergyPlus. Hope that helps.See the question below for resources.
| 4 | No.4 Revision |
For air flow it looks like you can set the air flow using the fields for these objects.
For fan power you'll need to use pressure rise to predict the output W and W/cfm W/L/s from EnergyPlus. See the question below for resources.
| 5 | No.5 Revision |
For fan power you'll need to use adjust the pressure rise to predict the output W and W/L/s output from EnergyPlus. See the question below for resources.
| 6 | No.6 Revision |
For fan power you'll need to you can adjust the pressure rise to predict the W and W/L/s output from EnergyPlus. See the question below for resources.
