I think you are trying to cool down your thermal zone using natural ventilation, right? Recently, I used EnergyPlus EMS sensors and actuators to open windows of a thermal zone during occupied period.
See below the way I defined actuators and sensors;
EnergyManagementSystem:Actuator,
Flow_Actuator37, ! Name
Block1:Zone1_Wall_5_0_0_14_0_14_Win, ! Component Name
AirFlow Network Window/Door Opening, ! Component Type
Venting Opening Factor; ! Control Variable
E01airTemperature, !- Name
Block1:Zone1, !- Output:Variable or Output:Meter Index Key Name
Zone Mean Air temperature; !- Output:Variable or Output:Meter Name
I think you are trying to cool down (decrease room air temperature of) your thermal zone using natural ventilation, right? Recently, I used EnergyPlus EMS sensors and actuators to open windows of a thermal zone during occupied period.
Occu_Schedule, !- Name
Office_OpenOff_Occ, !- Output:Variable or Output:Meter Index Key Name Occupancy Schedule
Schedule Value; !- Output:Variable or Output:Meter Name
One sensor is for occupancy schedule and the second one is for zone air temperature. P.S: There are other ways of simulating natural ventilation in EnergyPlus as well.
temperature.
