HVACDiagram that comes with EnergyPlus will help you visualize the IDF model that you have already created. It is not exactly what you want but will help verify what you have done. It runs as part of the EP-Launch that comes with EnergyPlus. Just open the SVG file. If you are not on WIndows, you need to run HVACDiagram by hand. You can learn more about it here. It is important to have a good SVG viewer, many internet browsers work but you might want to consider Inkscape or other programs that are dedicated to viewing drawings.
