To schedule in MS-DOS or the CMD shell you can use the AT command or SCHTASKS program which are available at the command line depending on your version of Windows/DOS. But these are really intended on scheduling a task that happens infrequently.
http://ss64.com/nt/at.html
For something that needs to run as often as once per minute, you should probably use something that just causes a delay for that long. The windows CMD shell/MS-DOS does not really have a SLEEP command built (it was available in an old Microsoft resource kit) so instead I have used the PING trick described on the following page:
http://ss64.com/nt/sleep.html
It is a hack but it works.
