I suggest looking at BEopt which will also run EP. You could quickly create a model in BEopt and look at or even use the IDF file that it creates to use in OS. Also, the House Simulation Protocols are a good resource for residential inputs in addition to Standard 90.2.
If you end up creating 90.2 constructions, consider uploading them to the BCL to make available for others.
