Hi Kostas,
This issue normally happens when DesignBuilder is running with a low-spec integrated card.
Could you please enable DesignBuilder to run with the dedicated GPU as described in this KB article:
How to check if the computer has a dedicated graphics card ? https://support.designbuilder.co.uk/index.php?/Knowledgebase/Article/View/189/4/how-to-check-if-the-computer-has-a-dedicated-graphics-card
If you are able to open this file on another machine, then save the model without results (File> Save > Save without output results) and delete all 2D floorplans in the model. This will reduce the file size.
Please contact DesignBuilder support team if you need more assistance.
Luis
Hi Kostas,
Luis
