@bingo Have you tried deleting your %USERPROFILE%/BCL folder? (eg: C:\Users\bingo\BCL)
If that doesn't work, please try https://github.com/openstudiocoalition/OpenStudioApplication/wiki/Enable-debug-output-messages-for-the-OpenStudioApplication and open an issue on https://github.com/openstudiocoalition/OpenStudioApplication/issues directly.
For what it's worth, I did try the OpenStudio 1.4.0 (newly released 12 days ago) on a Windows 11 clean virtual machine and can say that it works: https://github.com/openstudiocoalition/OpenStudioApplication/releases/tag/v1.4.0
Please do note that I'm talking about Windows 11 with an x64/amd64 architecture (the vast majority of cases). If you try to use an arm64 (such as running a windows 11 virtual machine on an M1 mac), it won't work.
@bingo Have you tried deleting your %USERPROFILE%/BCL %USERPROFILE%/BCL folder? (eg: C:\Users\bingo\BCL)C:\Users\bingo\BCL)
| 4 | No.4 Revision |
@bingo Have you tried deleting your %USERPROFILE%/BC%USERPROFILE%/BCLL folder? (eg: C:\Users\bingo\BCL)
