You can change the wall Outside Boundary Condition settings in the Inspector. From within Sketchup, this is accessed with the button that has the icon which looks like a magnifying glass and a square inside of it. You can either go into each space (double-click on the space) which has external walls, select each surface and select the "Ground" boundary condition to change it from "Outdoors".
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Ground. Then select each surface (the rest of the model with hide after you search selection) and change the definition in the Inspector; or you can write a script to change the boundary condition definition of all surfaces at once. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
More information on the Inspector and Surface Search utility can be found here; scroll about halfway down on the page under the Information Tools heading: http://nrel.github.io/OpenStudio-user-documentation/next_steps/sketchup_plugin_interface/
More information on the Inspector and Surface Search utility can be found here; scroll about halfway down on the page here under the Sketchup Plugin, Information Tools heading:
http://nrel.github.io/OpenStudio-user-documentation/next_steps/sketchup_plugin_interface/Tools:
| 4 | No.4 Revision |
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Ground. Condition:Outdoors. Then select each surface (the rest of the model with hide after you search selection) and change the definition to Ground in the Inspector; or you can write a script to change the boundary condition definition of all surfaces at once. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
More information on the Inspector and Surface Search utility can be found here under Sketchup Plugin, Information Tools: http://nrel.github.io/OpenStudio-user-documentation/
| 5 | No.5 Revision |
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Outdoors. Then select each surface (the rest of the model with hide after you search selection) and change the definition to Ground in the Inspector; or you can write a script to change the boundary condition definition of all searched surfaces at once. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
| 6 | No.6 Revision |
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Outdoors. Then select each surface (the rest of the model with hide after you search selection) and change the definition to Ground in the Inspector; or you can write a script to change the boundary condition definition of all searched found surfaces at once. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
| 7 | No.7 Revision |
You can change the wall Outside Boundary Condition settings in the Inspector. From within Sketchup, this is accessed with the button that has the icon which looks like a magnifying glass and a square square/cube inside of it. You can either go into each space (double-click on the space) which has external walls, select each surface and select the "Ground" boundary condition to change it from "Outdoors".
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Outdoors. Then select each surface (the rest of the model with hide after you search selection) and change the definition to Ground in the Inspector; or you can write a script to change the boundary condition definition of all found surfaces at once. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
| 8 | No.8 Revision |
You can change the wall Outside Boundary Condition settings in the Inspector. From within Sketchup, this is accessed with the button that has the icon which looks like a magnifying glass and a square/cube inside of it. You can either go into each space (double-click on the space) which has external walls, select each surface and select the "Ground" boundary condition Outside Boundary Condition to change it from "Outdoors"."Outdoors", or:
| 9 | No.9 Revision |
You can change the wall Outside Boundary Condition settings in the Inspector. From within Sketchup, this is accessed with the button that has the icon which looks like a magnifying glass and a square/cube inside of it. You can either go into each space (double-click on the space) which has external walls, select each surface and select the "Ground" Outside Boundary Condition to change it from "Outdoors", or:
You can also select all floors that are underground and use the Search Surfaces utility then "search selection" for class:Surface, type:Wall, Outside Boundary Condition:Outdoors. Then select each surface (the rest of the model with hide after you search selection) and change the Outside Boundary Condition definition to Ground in the Inspector; or you "Ground" in the Inspector. You can write a script to change the boundary condition definition of all found surfaces at once. once if you want to automate the change and use in the future for example. Be sure to Unhide All in the Search Utility afterward so the rest of your model will reappear.
