If you are not familiar with HVAC systems modeling, I suggest that you use default libraries or existing measures related to any HVAC system in mind. You can search for measures related to fan coil systems (for instance, a measure called NZEHVAC contains several fan coil system configurations) from Components & Measures > Find Measures and then apply that measure using Components & Measures > Apply Measures Now. This way you will be able to inspect the HVAC system scheme and its components, and then you can fine tune the system before running it.
