In DB output tab Cooling load are graphed with negative values: with an higher cooling set point (from 24 to 26) your cooling load (and consumption, I suppose) is reducing (from 5000 to 3000)
from help page, (pleaes see here)
Cooling always shows as a negative heat gain in the results.
Moreover, do not fall into errors by confusing Zone sensible/total cooling and System sensible/total cooling (see the same help page)
