Take a look at your model in Sketchup (using either the OpenStudio or Euclid plugins). You'll see there are a number of walls on top of each other, instead of being a single wall. With zone isolation turned on, double click into zones, you'll see walls disappear that should be part of the zone. Also some random walls/doors in the middle of zones. The doors that are different shades of green (in the image below) indicates that they are on overlapping walls, instead of walls shared between two zones.
