By default, OpenStudio adds the Zone Mean Air Temperature and Zone Relative Humidity output variables to a simulation IF you are applying the OpenStudio Results reporting measure. To avoid the max 255 column limit when using ReadVars to convert the ESO output file into a CSV file, you have a few options:
