Try removing the IDF Editor keys from the Windows Registry. To do this click on the Windows button and start typing Registry. That should allow you to open the Registry Editor. Go to HKEY_CRRENT_USER then SOFTWARE then VB AND VBA PROGRAM SETTINGS. You should see IDF Editor. Right click on IDF Editor and select delete and then OK when it asks if you want the subkeys deleted.
I'm not certain this will work but it is worth trying.
Try removing the IDF Editor keys from the Windows Registry. To do this click on the Windows button and start typing Registry. That should allow you to open the Registry Editor. Go to HKEY_CRRENT_USER HKEY_CURRENT_USER then SOFTWARE then VB AND VBA PROGRAM SETTINGS. You should see IDF Editor. Right click on IDF Editor and select delete and then OK when it asks if you want the subkeys deleted.
