This resource is not a document, but the template HVAC systems in OpenStudio line up pretty closely with the 90.1 Appendix G system types and the GUI makes diagrams that are pretty simple. To view them:
System types 1 and 2 are pieces of zone-equipment that can be seen by clicking on the thermal zones tab in the left column and dragging a PTAC or PTHP from the library on the right into the zone equipment drop zone.
If you are presenting these often, you could take screenshots of these, make a PowerPoint, and post the slides so that in the future this question has a better answer.
