@RedouanMa these should really be two separate posts (one for .ddy file and other for severe error).
Normally you download .ddy files for the .epw file you can obtain from the EnergyPlus weather site. If the .ddy file for Fez Morocco is not on that site, there are posts on Unmet Hours about getting ddy files from other sources here, here, and here.
In order to know how to help you with the error causing your simulation to stop, we will need to see either the .osm input file for OpenStudio or the .idf input file it creates for EnergyPlus along with the .err error output file. You can find the error file under the folder OpenStudio creates with the same name as your .osm file, then under the "run" folder. You can use Dropbox, Google Drive, etc. to provide links for others to access these files and help you.
