I just downloaded and tested.
YES, IDF+ does work on mac!
mac!
Steps to download and install:
The last one launches IDF+
I just downloaded and tested. YES, IDF+ does work on mac!
| 4 | No.4 Revision |
The last one launches IDF+IDF+. I had to locate the idd file from energy plus to open an idf file. It looks like you can also put idd files in /Users/username/Library/Application\ Support/IDFPlus/ and it will find them there. It also copies the idd there once you've located it so you don't need to locate the idd again for that version.
