|  1 |    initial version    |
If you want to use 2.7 after installing 2.8, you have a few options. One is just to re-run the 2.7 installer, and it will re-set the SketchUp plugin to use OpenStudio 2.7. You will still have both 2.7 and 2.8 installed on your machine, this just changes which is associated with the SketchUp plugin.
You can also follow old post on manually installing the SketchUp Plugin. And as a variation on this you can edit the existing configuration file by hand with a text editor to change which version of OpenStudio it loads.
