I think the eppy solution would be a script that populates the SizingPeriod:DesignDay objects based on the data from the DDY files. Another possible solution using Python is to append the appropriate DDY file that has the same name as the epw file. See:
https://stackoverflow.com/questions/13613336/python-concatenate-text-files
