Did you open one of the files from this directory in another application (like Excel)? If so, then BEopt cannot delete the temporary simulation directory because a file is in use.
If worst comes to worst and you can't get around this issue, try restarting your computer.
Did you open one of the files from this TEMP1 directory in another application (like Excel)? If so, then BEopt cannot delete the temporary simulation directory because a file is in use.
