1 | initial version |
EnergyPlus can produce output on a daily basis by specifying Daily in the report frequency field of the Output:Variable input object or in the Output:Meter input object. These generally produce a CSV file that can be opened with a spreadsheet program. To see what output variables are available for a specific file you should include the Output:VariableDictionary input object and run a simulation to see the list in the RDD and MDD files.
