click to hide/show revision 1
initial version
Looking at the hourly output for the chiller and the pumps, the condenser pump only runs when the chiller operates, which does happen throughout the year. The chiller (Chiller:Electric:EIR) condenser flow rate is the full flow rate whenever the chiller operates, regardless of load.
I have posted new issue 7111 to fix this or add a new option if there is a reason to keep this mode (variable evaporator flow with constant condenser flow).
Reference helpdesk ticket 13133.
