The approach of using select run periods (four one-week long run periods) with EnergyPlus to shorten run time has been considered for code compliance tools such as COM-Check by PNNL and included with CBECC-Com by the California Energy Commission because it provides a remarkably good indicator of energy usage and uses only about a quarter of the time.
PNNL has documented this approach in the report:
The Julian's response answers the bulk of your question but regarding the approach of using select run periods (four one-week long run periods) with EnergyPlus to shorten run time has been considered for code compliance tools such as COM-Check by PNNL and included with CBECC-Com by the California Energy Commission because it provides a remarkably good indicator of energy usage and uses only about a quarter of the time.
Julian's Julien's response answers the bulk of your question but regarding the approach of using select run periods (four one-week long run periods) with EnergyPlus to shorten run time has been considered for code compliance tools such as COM-Check by PNNL and included with CBECC-Com by the California Energy Commission because it provides a remarkably good indicator of energy usage and uses only about a quarter of the time.
| 4 | No.4 Revision |
Julien's response answers the bulk of your question but regarding the approach of using select several short run periods (four one-week long run periods) with EnergyPlus to shorten run time has been considered for code compliance tools such as COM-Check by PNNL and included with CBECC-Com by the California Energy Commission because it provides a remarkably good indicator of energy usage and uses only about a quarter of the time.
