As was also suggested by @Archmage, the problem lies with your operation scheme. Having had a similar problem recently with two water heaters on the same loop, the problem will be solved by adding a PlantEquipmentOperation:ComponentSetpoint
object.
The relevant section in the docs.
I'm not at all clear on why this is the case. That is, why a PlantEquipmentOperation:HeatingLoad
scheme controlling multiple plant items in a PlantEquipmentList
doesn't work. There doesn't seem to be anything explaining this in the documentation and I've seem odd behaviour at times so I'd be interested in a more comprehensive answer that gives the reasoning/logic behind it.
![]() | 2 | No.2 Revision |
As was also suggested by @Archmage, the problem lies with your operation scheme. Having had a similar problem problem recently with two water heaters on the same loop, the problem will should be solved by adding a PlantEquipmentOperation:ComponentSetpoint
object.
The relevant section in object for the docs.loop rather than the PlantEquipmentOperation:HeatingLoad
you currently have.
For reference, here's the section in the docs about plant and condenser control, though to me it's not clear how to work out the issue from reading it.
