It seemed that running an .osm file from the measures folder created this error. Some loop is created that creates an infinite depth of directories.
So: Never run an .osm-file from the measures directory!!
Some loop occurs, recursively creating more and more directories. You'll be unable to delete the directories, since filenames are too long.
To remove these files, you need to use subst from command prompt and assign a drive letter (quite ugly solution, but works). Proceed as follows:
![]() | 2 | No.2 Revision |
So: Never run an .osm-file from the measures OpenStudio\Measures directory!!
