I have tackled this by an EnergyPlusMeasure, to
Water:Use:StorageWater:Use:GroundwaterWellThe heart of the code in the measure is copied below. However, it has not been succesfull.
There seems to be an issue with the EnergyPlus calculations, my reasoning is;
The Well Requested Volume Flow Rate is enough to refill the Tank in one timestep. !- Pump Rated Flow Rate {m3/s} is limited (by me) to 3 l/s Tank Inlet Volume Flow Rate) is as per user entry This looks like a bug in EnergyPlus - the Water:Use:Storage is assumed to refill at the requested rate, even when the user has tried to limit this rate.
# add a new WaterUse:Storage object to the model
new_water_storage_string = "
WaterUse:Storage,
Cooling Tower Water Storage Tank, !- Name
Mains, !- Water Quality Subcategory
#{tankVolume.to_s}, !- Maximum Capacity {m3}
#{tankVolume.to_s}, !- Initial Volume {m3}
#{pumpFlowRate.to_s}, !- Design In Flow Rate {m3}
, !- Design Out Flow Rate {m3}
, !- Overflow Destination
GroundwaterWell, !- Type of Supply Controlled by Float Valve
0.20, !- Float Valve On Capacity {m3}
#{tankVolume.to_s}, !- Float Valve Off Capacity {m3}
0.10, !- Backup Mains Capacity {m3}
, !- Other Tank Name
ScheduledTemperature, !- Water Thermal Mode
Thermostat Always 18, !- Water Temperature Schedule Name
, !- Ambient Temperature Indicator
, !- Ambient Temperature Schedule Name
, !- Zone Name
, !- Tank Surface Area {m2}
, !- Tank U Value {W/m2-K}
; !- Tank Outside Surface Material Name
idfObject = OpenStudio::IdfObject::load(new_water_storage_string)
object = idfObject.get
wsObject = workspace.addObject(object)
# add a mains staging tank WaterUse:Storage object to the model
well_string = "
WaterUse:Well,
Cooling Tower Transfer Pumps, !- Name
Cooling Tower Water Storage Tank, !- Storage Tank Name
, !- Pump Depth {m}
#{pumpFlowRate.to_s}, !- Pump Rated Flow Rate {m3/s}
, !- Pump Rated Head {Pa}
#{pumpPower.to_s}, !- Pump Rated Power Consumption {W}
, !- Pump Efficiency
, !- Well Recovery Rate {m3/s}
, !- Nominal Well Storage Volume {m3}
, !- Water Table Depth Mode
, !- Water Table Depth {m}
; !- Water Table Depth Schedule Name
# Load it up
idfObject = OpenStudio::IdfObject::load(well_string)
wellObject = workspace.addObject(object)
# Clobber the Cooling Tower IDF Object - insert Tank Name
water_connections_objs = workspace.getObjectsByType("CoolingTower:VariableSpeed".to_IddObjectType)
sel_water_connection = water_connections_objs[0]
water_connections_objs.each do |water_connections_obj|
water_connections_obj.setString(23,"Cooling Tower Water Storage Tank")
# magic number hardcoded to suit object/e+version. tch tch.
runner.registerInfo(water_connections_obj.getString(23).to_s)
end
