If you are using EP-Launch, go to VIEW .. OPTIONS .. MISCELLANEOUS and check "Convert ESO/MTR to IP Units" and that will convert all output variables that have the string "elec" in their name to be output in kWh.
That option calls a program called convertESOMTR.exe which is located in the directory:
and uses a file called convert.txt in the same directory which you can open with a text editor to do what ever conversions you want. It is documented in the AuxiliaryPrograms.pdf file and also here. You could change the convert.txt file to make all J values convert to kWh.
You could change the convert.txt file to make all J values convert to kWh.kWh. To do this move the line:
conv,J,kWh,2.77778E-07,0
to before the line:
conv,J,kBtu,9.4845E-07,0
