You can rotate the building to adjust orientation in SketchUp and will be recognized in OpenStudio and the simulation. See this forum post. The green line indicates north.
You can also just the north access in the OpenStudio app. See this forum post. An orange line will appear in SketchUp showing your new north axis.
You can also just adjust the north access axis in the OpenStudio app. See this forum post. An orange line will appear in SketchUp showing your new north axis.
You can rotate the building to adjust orientation in SketchUp and it will be recognized in OpenStudio and the simulation. See this forum post. The green line indicates north.
You can also adjust the north axis in the OpenStudio app. See this forum post. An orange line will appear in SketchUp showing your new north axis.
