Openstudio currently support run periods of more than 12 months (credit: @David Goldwasser)
Using multiple years works fine in EnergyPlus. This recent thread on the E+ Support group should be of interest. It states that the trick is just to copy-paste values in the epw file spaning more than one year.
A few things:
I suggest using only one year for the calibration.
Using two years will complicate the process, and you're more likely to have a number of factors in there that you can't explain: over two years the parameters that define a building are more likely to have changed, whether it be its envelope, something on the HVAC side that broke, or a change in occupancy/vacancy...
Previous questions on Unmet Hours that should be of interest:
For example, I have briefly used ExcalibBEM - a GUI for the optimization tool GenOpt - and it really poked my interest for calibrating existing buildings and I definitely intend to dig further.
Openstudio currently support run periods of more than 12 months (credit: @David Goldwasser)Goldwasser )
A few things:
Openstudio currently does not support run periods of more than 12 months (credit: @David Goldwasser )
A few things:
| 4 | No.4 Revision |
A few things:
| 5 | No.5 Revision |
A few things:
This will potentially have another advantage for you right now in the sense that you'll be able to stay in OpenStudio, which does allow you to import utility bills and calculates metrics such as the Coefficient of Variation of the Root Mean Square Error, CV(RMSE).
| 6 | No.6 Revision |
A few things:
Also:
