Another description for this topic:
The Fan Coil Total Cooling Rate is about the condition between R.A. and S.A.
The Cooling Coil Total Cooling Rate is about the condition between M.A. and S.A. (including fan heat)
The Cooling Coil Total Cooling Rate is about the condition between M.A. M.A.(R.A.+O.A.) and S.A. (including fan heat)
