The opening/closing part can be implemented with blocks from the Modelica Standard Library. What is missing is a model that computes ventilation through an open window based on the window opening, wind speed and possibly temperature differential between room and outside. If you have such a correlation that is applicable for your building, you could implement it in a block and then prescribe this inflowing or outflowing mass flow rate between the outside and the room model.
