Could have been helpful to share what type of AC system you plan on using, but either way I think you can do the following:
This would look like the following, making sure you replace the 'Sensor Node' by a valid Outside Air node
AvailabilityManager:HighTemperatureTurnOn,
AC HighTemp Turn On Availability Manager, !- Name
Outside Air Inlet Node, !- Sensor Node
29.0; !- Temperature {C}
Package the AvailabilityManager:HighTemperatureTurnOn
into an AvailabilityManagerAssignmentList
Use this assignment list into your zone air conditioner. For example, if you use ZoneHVAC:PackagedTerminalAirConditioner
, you would put it into the Availability Manager List Name
