For DesignBuilder free-cooling heat exchanger go to HVAC system and select waterside economizer template.
Replace the cooling tower with a dry cooler.
Right click on CHW Loop Supply Side and chose the HX working schedule. Don’t forget to enter the HX design flow rate, free cooling and control type. Adapt your system as needed.
Replace the cooling tower with a dry cooler.cooler.
Right click on CHW Loop Supply Side and chose the HX working schedule. Don’t forget to enter the HX design flow rate, rate and free cooling and control type. Adapt your system as needed.
