Having a space within a space in your model will create non-convex surfaces with holes. See this post] for a better explanation of the issue. It is best practice to avoid non-convex space in your model.
You have two options:
Having a space within a space in your model will create non-convex surfaces with holes. See this post] for a better an explanation of the issue.
Having a space within a space in your model will create non-convex surfaces with holes. See this post for an explanation of the issue.
It is best practice to avoid non-convex space spaces in your model.
| 4 | No.4 Revision |
Having a space within a space in your model will create non-convex surfaces with holes. See this post for an explanation of the issue. It is best practice to avoid non-convex spaces in your model.
| 5 | No.5 Revision |
| 6 | No.6 Revision |
| 7 | No.7 Revision |
