Ideal Load Air System is a concept totally equivalent to purchased air. Check the input output reference manual. You can use:
HVACTemplate:Zone:IdealLoadsAirSystem HVACTemplate:Thermostat
You can use:use the HVACTemplate objects for convenience:
HVACTemplate:ThermostatOr the ZoneHVAC:IdealLoadsAirSystem directly.
